littletoes
- Aug 8, 2010
- 23
OK guys, here I am, dirrected here from a tractor forum.
Like the heading says, I have a 4.3 L V6 OMC with tilt/trim problems.
What I think I've found is the tilt/trim motor is bad. It has a three prong outlet from this little motor, with the black wire being the ground, and two other wires, each coming from a solenoid, one for "up", and the other for "down".
I "jumped" the ground wire to the negative on the battery, and then jumped each of the other prongs (first one than the other) to the positive end of the battery.....Nothing.
I'm thinking this means the little drive motor for the tilt/trim is fried. It didn't make any noise, nor attempt to move. I didn't think of hitting the body of the motor with a tester to see if it went to ground from a possible burnt winding, don't know.
Does this sound right to you guys? Or am I testing the motor the wrong way???
Any help is appreciated, thank you Gentlemen!
