Yes I have just got through resealing the bottom foot and tried to put it back on, it will bolt up but when you shift into reverse the prop wont rotate counter clockwise but insteads just goes in clockwise formation, when you shift into neutral the same problems arises. Now when you shift into forward it will rotate clockwise like it is suppose to but it sounds like the splines are slipping when turning the prop by hand, but it does this when shifted in neutral or reverse. Does anybody have any clues on what needs to be done when I install the foot.
By the way type of outdrive I have is a 120/140 mercruiser.
THanks
THanks
