Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
why is my 1-wire alternator setup not charging?
  • why is my 1-wire alternator setup not charging?
    i'll try to explain this the best i can... if more info is needed let me know
    i have a 72 winner wildcat with a 307 small block chev... i believe it originally had the 160 i4...
    after 1 battery went dead,,, i decided to look into it a little more... (pulling a cable off the battery when running kills the motor)
    i had the old alt tested & was told it failed... i bought a new alt for a small block & installed it,,, ran the motor & tested the voltage with a meter & its the same as the battery voltage when not running...
    the old alt had an internal regulator but nothing was connected to it... the new alt is the same & i installed it the exact same way as the old one...
    i looked for an external regulator under the dash & in the engine compartment & found nothing... as far as i can tell,,, the bat wire from the alt runs to the dash ammeter & then runs from the meter back to the battery post on the starter solenoid...
    so what gives??? i tried testing the bat wire right off the alt while it was running & its still the same voltage as the battery when not running...
    i've looked for info on the web about 1 wire alt setups & theres something about "exciting the regulator to induce a charge"... what does that mean???
    i either toasted or bought a junk new alt or the boat is wired wrong...
    i'm at a loss,,, any suggestions???
    Re: why is my 1-wire alternator setup not charging?
    do i need a "self exciting regulator" & run a jumper wire from the bat terminal to the #2 terminal as shown here???
    http://mightymo.org/Proj_OneWire.html#How%20it%20works
    • #3
      If you pull the cable off the battery with the new alt, does it kill the engine?
      Edit
      sorry if I understand the way its hooked up it will kill the engine when you disconnect it because your breaking the connection to the engine.
      Hook the wire from the altinator to the starter and then disconect the battery. If it stays running the Alt is good.
      As for the voltage reading, check it from the wire at the altinator. It will loose voltage as it runs through every thing.
      1987 Four Winns 215 Sundowner...
      She may be old...but she's got it were it counts!
      My refit/re-power project
      http://forums.iboats.com/showthread....13#post2466813
      3.7L rebuild: the thread
      http://forums.iboats.com/showthread....13#post2578113
      3.7L/470 altinator set up for about $100 with little modification needed and simple tooles.
      http://forums.iboats.com/showthread....=1#post2892577
      • #4
        Stop disconnecting the battery with the engine running!
        If you disconnect the battery while running your engine you will kill your alternator in a heartbeat. If you have already done that trick with your new alternator, you killed that one too.
        1998 Wellcraft Eclipse 24 Cuddy
        Volvo Penta Duo-Prop 7.4L "LK"
        2006 Sun Tracker Party Barge 21
        Mercury 90 4-Stroke FI
        "Common sense is not very common"
        "Failing to prepare is preparing to fail." -- John Wooden
        • #5
          ......you do realize that most one-wire alternators require an engine speed of approximately 1,000 r.p.m.s for the alternator to 'self-excite'. Afterwards, as the engine returns to idle, the alternator will continue to....well, alternate.
          Eddie Petty. #3 Dirt Modified
          Courtland, Virginia
          V-20 Wellcraft
          3.7 470 Mercruiser
          Stumpnocker
          25 Yamaha, 25 Johnson, 25 Evinrude, 9.9 Evinrude, 4 Johnson, 2.5 Johnson
          • #6
            Beat me to it.
            1988 Barretta Success with a 3.7
            Seems like it is out of the water more than it is in.
            • #7
              i had the old alt tested again,,, failed... i had the new alt tested,,, good... but was told the bearing is close to shot (made alot of noise on the machine)
              yes i know it needs 1000+ rpms,,, but what i dont get is we tested it at about 2000rpms & it was still the same voltage as the battery when the motor was off...
              is it because the new alternator doesnt have the self exciting regulator??? or possibly a bad ground on the alternator???
              i think i'm going to get the old alt rebuilt & go from there...
              • #8
                deleted...misunderstood previous post.
                • #9
                  edit
                  nevermind
                  ugh,,, it's been a bad week for me in the boating world...
                  1st the motor on the mini blew (http://forums.iboats.com/showthread.php?t=402662) and now this...
                  • #10
                    When you have it back together, read the voltage on the Orange wire with the motor off.It should be the battery voltage.Is there by chance a square plastic looking block at the starter ?
                    NO PERSONAL QUESTIONS, THIS IS WHAT THE FORUM IS FOR.
                    • #11
                      by orange wire,,, do you mean the wire thats off the alts bat terminal???
                      theres nothing at the starter except the starter itself & the solenoid...
                      i'll be bringing the old alternator in to a repair shop later this afternoon & hopefully he can steer me in the right direction so it will charge at a decent rpm...
                      i basically only use this boat for wakeboarding (2600-2800rpm),,, and slow cruising around the lake (1000-2000rpm)... anything above 3000rpms really eats the gas...
                      • #12
                        In most application the wire from the alternator is orange and it runs to the starter terminal directly. The batter cable also runs to the starter and that is how the power gets from the alternator to the battery, instead of how yours is hooked up, from alternator to battery then battery to starter.
                        So if you check the voltage from the location on the starter where those two wires meet, you should read 12 VDC, witch is what the battery is putting out when the motor is off. When you start the motor and bring it up to 1500rpm you should read 13-15 VDC at the same location.
                        • #13
                          mine is wired from the alternator to an ammeter & then back to the starter... but yea,,, i poked it at a bunch of different locations (directly off the alt, at the ammeter,,, at the starter etc) & it all read the same at different speeds...
                          i brought it to an alternator/starter repair shop & the guy told me it'd need to hit at least 3000rpms to start charging (again,,, which the boat is rarely run at,,, it uses WAY too much gas,,, unless a storm is coming & i need to get back to shore quickly lol)
                          but he said since its a 42amp,,, he could get it to start charging at around 850rpms...
                          • #14
                            If I were you I would ditch the ammeter and just run the wire directly to the starter solenoid. That way you don't have to run all the way to the dash and back. Replace the ammeter with a voltmeter.
                            • #15
                              GM 1 wires "excite" at about 1000 rpm , once excited they will remain charging untill it stops spinning.
                              Back to Top
