Working on an Alpha One Gen II and trying to split the case on the lower unit to service the water pump, but the shorter bolt that ties them together from underneath near the pin in back has broken.
I've found some good links on how to take out a broken off bolt and if I don't have left hand drill screws I will buy them, but is there anything to watch out for or make the job easier? What about applying heat from a propane torch - good idea or not?
http://www.secondchancegarage.com/public/671.cfm
http://www.madelectrical.com/workshop/broken-bolts.shtml
