duped
- Aug 26, 2009
- 307
Hello everyone. I am looking for direction in how to fix this problem. I noticed after taking the boat out yesterday that it leaked some oil in the driveway with the drive tilted up. 1986 Alpha one, 230 HP...
It appears to be coming from lower shift rod. The one that slots into the u shaped thing. The U shaped one is solid, however the bottom rod is loose, and has about a 1/4 up and down movement, as well as a small amount of side to side play. In the picture you can see its barely even in its groove. Cant be normal can it? Either way a leak isnt..
So what went wrong, and how do I fix it??? The thing was working/shifting great when I brought it in.
Edit, I checked out how things were on my dads boat, and my other boat, and all of the lower shift rods seemed to have that play in them. So should I even bother being worried about a drop here and there? I'm gonna change gear oil and examine for water intrusion either way...
