Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
2002 5.7 mercruiser cranking problems
  • 2002 5.7 mercruiser cranking problems
    I have had a cranking problem about 3 yrs now. No mechs. can tell me what the problem is.
    Sometime (mostly after it sets for a few days) when I try to start it, as soon as I release the key it will try to start. Sometimes it takes 10 or 12 trys. I have installed a New Marine 750 cranking amp battery, new altanator and spark plugs and having the same old prob.
    Can anyone tell me why it trys to start when you release the key??? Whats the Problem!!!!!!
    Thanks in advance
    pd boat
    Re: 2002 5.7 mercruiser cranking problems
    Ayuh,... There should be the outside little wire on the starter powering the igntion while cranking....
    My guess is, you Don't have that wire hooked up...
    • #3
      Wait are you stating it will attempt to start on its own when the key is released? In other words it cranks without the key being on or that it will not start until the key is released?
      1988 Barretta Success with a 3.7
      Seems like it is out of the water more than it is in.
      • #4
        Yes your right...when you turn the key, engine will turn over like its suppose to but it wont try to start until you release the key. I've been told that the starting mechanisum must have at lease 11.9 amp for the engine to crank up. I have about 12.3 to 13 amps now with the new battery.
        I have changed the key switch but it still does the same thing (sometime) if it has been setting for a few days.
        SPOOKY!!!!!!!!!!!!
        PD BOAT
        • #5
          SPOOKY!!!!!!!!!!!!
          PD BOAT
          That sounds like the firing circuit. Perhaps the coils or the distributor. Check for spark when cranking bet it is not there.
          Is there an assist solenoid and a safety switch on this?
          • #6
            You may be right about the firing circuit or solenoid but I just put on new distributor and cap.
            I don't know about assist solenoid but there is a lanyard switch. I don't think its any of these things...I'm thinking its in the computer system.. reason, sometimes it will start right up and sometimes it wont start until the keyswitch is released. The mech I had the boat worked on said that he checked firing, compression,fuel pressure,spark and for a while after I got the boat back from the mech it started great. Now its back to its same old s*#T!!!
            pd boat
            • #7
              ....as Bond-o has suggested, you should have a small wire running from the starter solenoid that powers the ignition when cranking.
              If I am remembering Chevy starters correctly, the solenoid should have two large terminals (one for supply voltage and the other across the solenoil washer to turn the starter) and two smaller wires (one to receive voltage from the key and power the solenoid and the opposite to provide starting ignition).
              Eddie Petty. #3 Dirt Modified
              Courtland, Virginia
              V-20 Wellcraft
              3.7 470 Mercruiser
              Stumpnocker
              25 Yamaha, 25 Johnson, 25 Evinrude, 9.9 Evinrude, 4 Johnson, 2.5 Johnson
              • #8
                Ayuh,... Now a days, that's pretty much a Marine thing,....
                Lotsa Chevy car starters lack the outside little terminal....
                • #9
                  Good point Eddie, but why will it start like its suppose to sometime and wont start until the key is released on other times? I don't know a lot about the newer engines but this one doesn't make sence to me..puzzeled!!
                  pd boat
                  • #10
                    Ayuh,.... I think that's Volts....
                    Corrosion in/ on the wire on the terminal We're talkin' about,..??
                    Back to Top
