Lochlomond
- Jul 8, 2010
- 19
Hi, help required for a year old issue with my 2003 nag 350 mpi, i have an intermittent spark issue from the coil, this can be trying to start the engine, out at low rpms or even at 4000rpm, i have traced the problem i think to the ecm not allowing the spark
I traced wiring today to find while cranking her and not starting and proving no spark at the coil i did have 12v at both the ignition coil and module so i can only see it as the ecm saying no spark mate
History - i have just replaced the coil & module for new, i have had access to reliable spare parts from same year and model as my engine and have tried the following - The ecm, fuel relay, power relay, neutral safety start switch, crankshaft sensor, HT lead all to no avail
I have had engineers look at it, twice had diagnostics connected with no fault codes or errors to report, at my wits end
Can anyone confirm what all sensors on this engine/year etc have an effect on the ecm to control the sparking as the coil is good, the ecm is good and voltage is there then some sensor must be telling porkies to the ecm
Help
Help
