WaterLauger
- Apr 22, 2003
- 25
I have a 23' Crestliner w/OMC 245. After going through the engine and manifolds, I wanted to check the alternator/charging system before putting her in motion for Memorial Day. I took the alternator to a local shop and it is producing 20 amps. I think this unit is rated at about 38-39 amps. Is this enough juice to charge the battery? If not, should I consider a higher output internal regulated alternator? What wiring nightmares should I expect?<br /><br />Thanks
