Hello everyone! I,ve been lurking on the forums since March when I bought a 17' Galaxy. I was having a ton of problems with it since the begining. Probably not my best purchase ever but I figured I would make the best of it. So far, here's what all I have done.
Replaced the floor and carpet
Had all bellows replaced
Had outdrive serviced with new impeller.
Had new headgasket installed.
Rebuild the carb.
Boat was running great. Had a friend with me on Friday. We were water skiing and having a great time. Went to just cruise down to a local place on the water to get a bite to eat. I was traveling at about 20mph. Motor seemed bogged down so I trimmed up a little. Then I lost ALL drive and engine revved up. I cut it down to an idle immediatly. Tried forward and reverse. Nothing. Also noticed the temp climbing up. Shut her down at about 160-180 degrees. Thought maybe I lost the prop. Jumped in and it was still there. Was able to spin it freely. Had friend put boat in drive, with motor off, and was able to spin the prop in both directions, with a small amount of force. That's when I knew I was in trouble. So I flagged someone down and they towed me back to the launch.
Did a little research on this site and decided to poke around. Let me back up and say that my outdrive is NOT an Alpha. It's before that. SOmething like an M/MR. So anyways, I pull the top of the outdrive off. All I see inside are metal shavings and rounded gears. NOT GOOD! So I take a couple of pictures and seal it back up. Now here's where my questions come in:
1. What should I do?? Rebuild or replace the outdrive? Can I ust get new gears?
2. The outdrive was completely serviced. I picked it up May 27th and maybe have 20 hours on it. Should I go back to the mechanic and blame him for the failure and make him fix it?
3. Scrap the boat .
Here's a picture of the carnage!
http://img.photobucket.com/albums/v470/TEODE/100_2814.jpg
Any information would be GREATLY appreciated. Thank you all for your time.
Rebuild the carb.
3. Scrap the boat .
