I have a 1980 Silverline 17' boat with a merc. 470. The shift mechanism that trips the shift interrupt switch is way off kilter, and I've been trying to adjust things for two weeks now with no fix. Once I adjust one thing, the other is off, etc. My main question is however; why such an extravegant mechanical system for such a simple switch? Couldn't one simply install a momentary switch circuit at the shifter itself to perform the same function? Am I missing something here? Seems to me that a simple momentary engine cut-off switch wired in conjunction with the shifter (from gear to neutural) would accomplish the same task, without having to rely on cable tension, etc. What do you think?
