Stillreelin
- May 3, 2010
- 23
I replace my 4.3 liter V6 mercruiser. New everything from the carb to putting fresh water on the motor. The problem that I am having is it won't go over 4400 rpms and when it is wide open,it will run smooth then will act like it drops 100 rpm then picks right backup. It will do this the hole time it is wide open.At 4200rpm it will run fine no issues. Any suggestions on what may cause this? (It is the same outdrive and prop as before)
