I got my engine, the alignment seems to be good but after reviewing the manual for the older engine I put in to replace my newer one I noticed the lock washer needs to be under the engine mount verses above it. Since my engine is in now and the outdrive is all hooked up it will be a pain in the *** to remove everything, raise the engine and fix the lockwasher placement. Do you think its a big deal? I seem to be aligned right...
Attached is a photo of the rear mounting setup that I missed.
