Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone elses topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when its posted at the end of someone elses topic. And those answers will be specific to your particular issue.
See more
See less
4.3 Mercruiser serious problem - Engines jammed
  • 4.3 Mercruiser serious problem - Engines jammed
    Hello FolksJust bought myself a 94 Stingray 18'6" walkthrough. Had it out three times with the wife and kids when starting it to go home the starter motor split (Right down the casting seem). After getting it home and pulling the Starter I thought it would be a good idea to confirm all the teeth on the fly wheel are intact which may have caused this mystery. Got almost all the way round hand cranking and inspecting when it came to an abrupt stop with a CLUNK. Mystery solved!! :o It looks like I'm going to have to tear into this motor and would like to know a few things. Like - are the 4.3 LX Mecruiser motor parts swappable with the GM six cylinder its made from (keeping in mind rotation and what not)-is there a motor rebuild/repair manual out there for this engine-is there a good site for parts (which will actually ship what you order)Any other comments or tips would be greatly appreciatedMy email is andfitz@softhome.netThanksAndrew
    Re: 4.3 Mercruiser serious problem - Engines jammed
    Sorry to here about your Clunk.....Here's some of the answers you seek,Yes, Your motor is the Same basic Motor run in a GM truck,... But You'll need to use Parts from the same Vintage....Rotation IS the Same....I've got a copy of the Mercruiser Service Manual #18.(GM V-6 262cid (4.3L) Gen.II with balance shaft.... It's a very throrough Manual... If you watch Ebay, You'll see one come up for auction after awhile....I buy 90% of my parts at NAPA, Ask for a copy of the NAPA cat.# MSP-7... It's the newest NAPA marine catalog.....The cover says it's $6.95, But I've Never Paid for one....Have you had any revalations as to What the Clunk Is ?????
    • #3
      www.ebasicpower.com has always done good by me for any engine parts I've needed...This web page may also be of some help... It has exploded views of some assemblys for your Mercruiser...
      I don't give interviews, and I'm no longer a public figure..
      • #4
        Thanks for the quick and GOOD responseNo to the "clunk" answer, I suspect either a valve dropped or a rod has taken on a direction of its own, but there are no additional "inspection ports" on the side of the crank case or oil pan.The sources you gave me are great.If you have any tips, hints, tricks or tools I should know about that would be great.BTW is there a difference between the starter you buy at NAPA and the one the Mercury site sells?ThanksAndrew
        • #5
          As long as the starter is specificaly rated for marine use, there's no difference... Marine starters, alternators, and distrbutors are all either sealed or have spark arrestor screens as not to allow any sparks out which could ignite any flamible vapors that may accumulate in your boats bilge/engine area.. You can also find starters Right Here in the Iboats MegaMall..
          • #6
            Sounds like you may be hydraulocking. Remove plugs and try to turn over engine again. Inspect plugs for signs of water. I use this website for reference and buying parts. Great folks... mercruiserparts.comBT
            • #7
              ThanksI will defiantly try the Hydrolock thing before going at the engine. Has anyone used the vented spark plugs?
              • #8
                I suspect you are right about the Hydro-lock. Motor was running fine and then the starter motor split, yes they will. You lost me with the "vented spark plugs"?? You need to find out why it got water in the cylinders and pay attention as to which ones do and do not have water. I have also had motors which over-rev create valve trouble but it would not have been on start up.
                • #9
                  Andfitz, before you tear into that motor, pull off the stern drive and see if it turns over....you can break either the upper or lower gear set and jam the engine, they are always turning with the engine....
                  • #10
                    PR/EP (Pressure Relief / Engine Protection) Spark Plugs I understand are specifically designed to protect engines against hydrolock damage. I found it here prep sparkplugs I'll go after hydrolock first and then to the outdriveThanksAndrew
                    • #11
                      Well ya learn something new every day, I've never heard of such plugs, any of you folks ever used them? Andy, be sure to remove the outdrive if removing the plugs doesn,t help,,,,,good luck...
                      The Devil to pay, and no pitch hot!
                      • #12
                        The Prep-sparkplug is an interesting concept, But, I think I'd rather Tune my engine properly, Rather than Rely on a Blown Sparkplug....Seems that once it Goes-Off, It's Junk,+ Must be replaced....I'll Stick with My ACs....
                        • #13
                          Popped the plugs and cranked it over - sure enough water came out (salt water). Looks like it may have drawn it in through the exhaust. I'll have to look into why that happened. Wonder if dieseling would cause that. Should I shoot a little oil into each cylinder and spin it over with the plugs out to clean it up? (that is after I pick up another starter)Looks like it was defiantly hydrolocked
                          • #14
                            By all means... YES, get some oil in there and turn it....ASAP...
                            • #15
                              Happen to me once, low motor high waves, we changed the oil 3 times that day. Also shoot some starter fluid in the chambers to dry up the water. The first thing to check is the flapper valves, mine were shot, changed em out no problem... so far.Good Luck
