mercruiser 3.0l compression
slredstorm62
i have an 87 mercruiser alpha one 3.0l and was wondering what the compression should be i have about 90 psi is that good or to low?
zbnutcase
Re: mercruiser 3.0l compression
Thats low, should be in the 130ish range.
slredstorm62
well it has been sitting for 3 years and i just put new headgaskets in it end of last season but never ran it. one of the techs i work with says that the old fuel can cause part of the problem. i have 90 90 90 then 60 in last cyl
Ayuh,... That's a rebuildable Core motor...
A Running motor should be 130 to 150psi, or more....
slredstorm62
i am gunna try put seafoam in the engine and see if i can clean it out before i try and rebuild the engine. dont want to waste time if i dont have to
tschmidty
Sea Foam won't do anything for compression, but can't hurt. Some people will hate this suggestion, but I have had some luck using a product called Restore to raise compression psi. You never want to count on mechanic in a can, but I have seen good results so might be worth the 6-7 bucks it costs.
slredstorm62
where do i get that from? id just hate to tear engine apart because i just put all brand new gaskets in it and they are about $100 i put hi-tac on them so i know they will be junk
tschmidty
Any auto parts store should have it, right next to the sea foam usually!
antsmands
My 86 3.0 has compression greater that 148psi in each cylinder. 90psi is quite low!
bruceb58
You should run it for a little bit and see if it improves because of how long it has been sitting.
Don S
I'm with bruce58. after an engine sets that long it's a waste of time to do a compression test.
I have done compression tests on engine with similar (even worse) results than you have, after running for only 5 minutes the compression was normal.
Start it up, get things moving and freed up and it may be fine.
Even rust spots on the valves will cause low compression like that. But running for even a few seconds would clean it out.
JustJason
+3
Start it, let it warm up at an idle, then run the snot out of it. Let it cool down, then redo your compression test.
