Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone elses topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when its posted at the end of someone elses topic. And those answers will be specific to your particular issue.
See more
See less
Upgrading a 2 barrel Rochester to a 4 barrel
  • Upgrading a 2 barrel Rochester to a 4 barrel
    I have a 3 litre GM OMC with a 2 barrel Rochester Carborator and I am looking to find out if anyone has converted their engine to a 4 barrel Carborator in order to increase horsepower. Any thoughts or suggestions ????
    I was thinking of a 4 barrel of approx. 490 CFM for this 180 cubic inch engine. Too much?, will it flood?, will I gain horsepower?
    other alternatives?
    Re: Upgrading a 2 barrel Rochester to a 4 barrel
    other alternatives?
    Nope,...
    Not really....
    • #3
      4BBL would be too much
      Baba-buoy.
      • #4
        350 cfm Holley marine carb is the max I would do on a stock 3.0-if I bothered at all. Only pencils out if you need a new carb anyway.
        You meet the nicest people at the American Legion.
        "maintenance is always cheaper than neglect"
        "certain parts are USCG approved for a REASON"
        "just because it's in the factory service manual, doesn't mean it's correct"
        • #5
          Id call that a drowning, not an upgrade.
          Upgrades make things better, and that wont.
          2011 Triton 190 Escape SE 150 Mercury Pro XS
          I never learned much from winning, but always learn from failure.
          Semper Fi
          • #6
            Yup, probably make more sense to put a 1 bbl carb on it than a 4. But that's a down grade too.
            • #7
              As others have said, a 4 barrel carb will not make any difference on your 3.0L. Any internal combustion engine is a pump, it sucks air in and pushes exhaust gases out. The carburetor on your engine is NOT the choke point that is restricting the flow through your engine. Essentially the same carburetor is used on the 4.3L, the 5.0L, and the 5.7L. One of the members here just replaced the 2 barrel on his 5.0L with a 4 barrel, you can see his results on this thread:
              http://forums.iboats.com/showthread.php?t=396275
              If you don't feel like reading the thread, I can summarize it for you: it made no difference at all.
              He was also using a manifold designed for a 4 barrel, not some hodge-podge of adapters like you would be forced to use on the 3.0L.
              Any opinions expressed above are worth exactly what you paid for them!
              • #8
                Well I guess I have my answer.
                Thank's guys.
                I just posted my question this morning and now I have a whole lot of info.
                Thanks also for the thread refferal.
                So, to better be able to do all the skiing with a boat full of people I guess I should invest in another prop rather than carb since it isn't going to give me any power increase.
                Yes, thank you all again.
