Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Mercruiser 5.7 EFI 2001 not starting after run
  • Mercruiser 5.7 EFI 2001 not starting after run
    Hello,
    I have a chaparral 2001 with a mercruiser 5.7 EFI. I can run the boat for most of the afternoon pulling daughter tubing, shutting off occasionally, and then at some point the boat will not start. Seems to be getting fuel but won't start. I can let it sit for about an hour to 1 1/2 hours and then it will start and run fine back to the dock. Usually load it and take it home.
    It is not getting hot and runs fine until this time. Thanks in advance for any thoughts
    Re: Mercruiser 5.7 EFI 2001 not starting after run
    Grab a copy of the merc service manual for that engine (you can download off here in the adults section) and get a scan tool. The manual pretty well walks you through the diagnostic procedure. Take both along next time you take the boat out as intermittents are usually hard to trace unless the malfunction is present at the time.
    Off the top of my head I'd say to check the fuel quality and filter (no ethanol or water contamination and I believe it needs 30 psi pressure) and unplug the MAP sensor next time it don't start. If defective they can also cause a no start condition. Easy to check, but do get a manual and scan tool. And dont use anything but a high impedance multimeter or you risk frying the ecu.
    • #3
      I had the same year and engine installed in my old boat. While still under warranty it had the very problem that you're experiencing. Took the dealer almost all summer to figure it out, but the fix was pretty simple- the ignition coil was getting hot and causing the engine to act up. Once it cooled down it was A-OK - for awhile.
      In my case, the coil had some black goo coming out. Once the dealer installed the new coil, the problem disappeared.
      • #4
        Yup, coil would do, or anything else electronic. Electronic defects usually show up under hot conditions.
        • #5
          Ayuh,.... During that hour to hour,+ 1/2,...
          Is the time to Diagnose the issue,...
          Actually Check whether it's lacking Fuel, or Fire....
          • #6
            You can also put that scan tool on right away and check to see if it has a diagnostic/malfunction code stored. You might get lucky.
            • #7
              Anybody have a recommendation on an inexpensive scan tool for boats?
              • #8
                I had a similar experience with my 260R - I would run fine for a while and then things would start bogging down and die at idle. This usually happened when I was running WOT for several minutes. I then could crank an crank and no start. Two things gave me a hint - I seem to be running a bit hot a WOT (5-8 degrees over normal) and after things cooled down I could restart (1 1/2 to 2 hours later). So definitely a heat related problem.
                I then replaced my ignition coil and spark plug wires and solved the issue. I am not sure which it was (coil or wire), but I have been running two weeks with no issues.
                Just thought I would relay my lessons...
                • #9
                  I had the same problem with mine 5.7 EFI
                  And it was ECM computer module.
                  I bought used on eBay for $350 and starts any time.
