bowriderbob
- Apr 7, 2002
- 16
ok guys, this is a weird one (for me, anyway). My Mercruiser 3.0L has always ran great. Tonight, we take it out, and it starts fine and then immediately quits. I go to restart, and there is nothing happening when I turn the key, and all the gauges on the instrument cluster are dead. I check the fuse block, and find that the fuse is blown for the ignition (?, it's a 25 amp fuse, and has a large wire coming off of it). I replaced the fuse, and as soon as I turn the key on, it blows again.<br />Any thoughts or suggestions on this one?<br />p.s. the only thing I've recently done is added a stainless prop, since the last time I ran it.<br />Thanks in advance<br /><br />update: I disconnected the leads on the alternator, replaced the fuse, and the boat started and ran fine on several attempts. I replaced the leads, and still no problems. Is this a bad connection in the leads, or alternator or regulator going bad ?<br /><br />BowriderBob<br />99 Vip 184<br />3.0L Mercruiser
