Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
98 Merc 4.3l Lean on one side?
  • 98 Merc 4.3l Lean on one side?
    98 Mercruiser 4.3l.
    New plugs, cap, and rotor this spring
    Since getting it out this spring it has a few issues. It will sometimes backfire through the carb usually only when cold and when you give it gas. It "pops" the worst on the muffs. It also has poor acceleration and will not reach wot. It did one day for a short period (surged) but hasn't since.
    I pumped gas out of the bottom of the tank and did not find any water.
    I believed it was a lean condition so I pulled the plugs. The plugs on the port side show lean, if any thing rich on the starboard. That is 1, 3, and 5 plugs were snow white, 2, 4, and 6 were dark brown to black.
    I am assuming this is a carb issue. Could it be anything else? 2 barrel Mercarb, if it is the carb could someone explain to me how they work and why it would be lean on only one side?
    Thanks again guys.
    Re: 98 Merc 4.3l Lean on one side?
    Ayuh,... Go ahead,+ Rebuild the carb,...
    You'll have a better understanding of How it does what it's doing after you rebuild it...
    • #3
      With the engine running spray the lean side of the intake manifold where it meets the cylinder head with some carb cleaner and see if the idle speed changes.You have the synptoms of a vacuum leak.
      If you can read this thank a teacher.If you can read it in english THANK A VETERAN
      • #4
        Update
        The popping and stumbling was not the carb. I finally checked the timing (I know, I should have done that when I changed the cap and plugs). It was about 2 degrees ATDC, set to 10 BTDC in base timing mode and now she purrs like a kitten. I am going to run it some and see if one side still shows lean as I realize the 2 issues may have not been related.
