nola mike
- Apr 22, 2009
- 5,072
can anyone tell me how the sender for the trim position sensor works? mine isn't accurate suddenly, and won't hit the bottom of the gauge even with the sensor adjusted all the way.
1. i would guess that the sensor is just a rheostat, but looking at the wiring diagrams, it appears that one sensor wire is grounded, and the other appears to go to...the oil temp gauge? (see diagrams). with the ignition on, it seems that there is power to the sensor. i'm missing something. are there testing parameters (ie, in trailer position there should be a reading of x volts/ohms, and at full in it should be y)?
2. my battery gauge is also suddenly reading low by 1-2 volts. i'm guessing these probs are related; i'll check main power and ground wires this weekend, but i'd like to know how the TPS works as well.
3. my "trim up" control also doesn't work, trailer does. i assumed that it had to do with my trim limit switch, but again, i'm not sure how it works--looks like a simple on/off switch? at below trim limit, looks like pressing the button connects blue/wht wire to 12v?
these wiring diagrams are tough to read--are there any "true" wiring diagrams available (eg, that show whether something is acting as a switch/resistor/etc, instead of just showing wires ending at a picture of the component)?
