Re: Swap v6 for v8
it's pretty straightforward even if you don't have enough stringer, you can add more.  the mounts only have to come forward a few inches - the engine is 4 1/2 inches longer, but the mounts only move 3 and some change....  the big question / concern is having enough room in front of the engine or being able to make it (4-5 inches).
OH, and being sure you're starting with a solid enough hull that has a design that won't be too much of a handful at higher speeds.
and you can definately reprop and run the same gear ratio, in fact on a smaller, lighter boat like yours it'll be fater with a higher pitch prop and lower gear ratio. That's based on theory, advice from guys who do it every day, and my own personal experience when i did pretty much the same thing.  Note that the difference between a 1.84 gear ratio and a 1.50 gear ratio is something like 21" to 27" prop change.  Lots of good props in both ranges and it'll be at least 4-5 mph faster with the higher gear ratio and higher pitch prop all oither things being equal and assuming you've got modern, well designed props to play with/
you will gain a hundred or so pounds in the back of the boat which can change handling characteristics.  you can offset by running aluminum heads, intake and exhaust, but that adds dollars (in addition to horsepower of course...).
overall, I'm very glad I did it in mine (17 1/2 foot).  In current configuration it handles great and has very good manners, I can pull the biggest skier out of the water with less than half throttle and when we put the hammer down all but the very fastest boats fall behind in a hurry...
Have fun with it!
