Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Idle Air Control Valve Location 4.3 Merc
  • Idle Air Control Valve Location 4.3 Merc
    Ive been looking around for a while and I am pretty certain the problem with my boat lies within the IAC valve. It either needs to be cleaned or replaced. The problem is, I have no idea where it is located. I have a 2003 Crownline 180BR with a 4.3l mercury engine. A little help here would be greatly appreciated. Thanks.
    Re: Idle Air Control Valve Location 4.3 Merc
    Sounds a lot like your troubleshooting procedure is to read what happens to others and start throwing parts at it.
    The IAC is on the throttle body if that helps.
    What you might want Click Here and download the proper service manuals for your engine and drive, and check it out properly.
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      Still no luck...is it possible that this engine doesnt have one? the S/N is ow000645
      • #4
        Of course you don't have one, you have a carbed engine, not an EFI.
        Why don't you post what your problem is, because reading the archives isn't doing you any good.
        Don S.
        • #5
          This should be your first thing to do.
          http://forums.iboats.com/showthread.php?t=220416
          NO PERSONAL QUESTIONS, THIS IS WHAT THE FORUM IS FOR.
          • #6
            Alright here goes. Sorry for that. I just pulled my boat out of storage after the winterization and i hook the ear muffs up and start it up. It will stay running at higher rpms but will fizzle off when shifted to neutral. It will crank right back up with ease but again when let off on the throttle it will fizzle down and shut off.
            • #7
              Ayuh,... It needs a Full,+ Complete Tune Up,...
              Probably a Carb Rebuild as well...
              Back to Top
