dieselram94
- Apr 14, 2010
- 94
I bought an entire set of GLM manifolds and risers with gaskets last summer. I am just now getting around to installing them and noticed one of the riser gaskets is damaged it is a two hole two slot gasket. Should I get a GLM replacement or go get oem gaskets? No instructions came with these so I looked on GLM website and they recomended using Right stuff sealer or Permatex #2 non hardening on the riser gaskets. Also all gasket surfaces are painted like the rest of the parts. I believe I should remove the paint from the gasket surfaces, check to make sure flat and install oem gaskerts dry. Is there anyway to know if these are leaking internally? I plan to drain after each use.
Hopefully you guys think I am on the right track.
