Here's an easy one. I'm changing out the exhaust manifold/elbow and risers on a 1998 mercruiser 4.3L v6. I have a closed cooling system. On the square gasket in between the manifold and elbow do you need sealant. The merc manual says to use mercury loctite 510 sealant. I'm not sure about using the sealant on the stainless steel gasket. Also what other brand of sealant is suitable. Thanks.
