Re: Bravo Two only slides back 1/2"
Anyone have any fix or procedures for this.
The TRS drive I ran into hadn't been removed since forever.
The gimble bearing had been greased every year.
The TRS moved about 1/2 inch.
Talked to Mercruiser about this, they took the position, "I can't tell you because I'm not there.
Chained the hull to the trailer.
Fitted a nylon strap to the top of the drive between the mating surfaces below the top two studs, ran the rest of the strap to the bottom of the drive, above the bottom two studs.
I used a ratchet hoist between a tree and the nylon strap.
I attached a rope between the lifting ring on the TRS drive to the top of the hull.
Ratcheted the drive off, no damage, an I didn't have to "Be careful".
When the drive finally came off, it shot out like a cannon ball.
After removal of the drive, I noticed the yearly greasing of the gimble bearing left a ton of grease on both sides of the bearing, of course the grease hardened, stopping the shaft from moving through the bearing.
