Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
adjusting lower shift cable - Alpha I
  • adjusting lower shift cable - Alpha I
    I'm trying to adjust the lower shift cable on an alpha I drive (motor is mercruiser 4.3 L V6). The instructions say to manually shift (push in on lower shift cable) the drive into gear while some one spins the prop. I've got that down - the drive shifts fine into gear. The instructions say to adjsut cable so that you measure exactly 6 inches from the center of the brass barrel to the cable end guide. Here's where I need clarification. Do I measure to the end/tip of the cable end guide or to the center of mounting hole.
    Re: adjusting lower shift cable - Alpha I
    info i have says pre set dimension is from center of barrell to the center of the hole in the plastic piece. i have used the procedure below with excellent results.
    http://www.mercstuff.com/images/shiftcable.jpg
    • #3
      What year?
      If you actually have an Alpha I, then go up to the adults only sticky at the top of the forum, and download service manual #6. Section 2 has step by step instructions with drawings on how to adjust it.
      I would be very careful with mercstuf info. It's not always accurate.
      Don S.
      Please, no PM's (Private Messages) regarding boat/engine problems.
      That is what the forums are for.
      Only forum/moderator issues will be answered in PM's.
      • #4
        Thanks for the replys. The drive is an Alpha I gen II (1998). I downloaded service manual 14 and instructions say exactly 6 inches from center of mounting hole (cable end guide) to center of adjustable brass barrel. The instructions I had were a little vague in this measurement.
        Hoot, I also printed out your instructions and will keep that for reference. Thanks again.
        Back to Top
