Re: Symptoms of engine water pump being bad?
what is it that makes you believe you are still overheating?
Factory guage is 1/32" of an inch from going into the red zone, and I can smell oil burning from the valve cover gasket. On a car it is normal, for a boat, I am not sure it should get hot enough to make a smell like that.
The intake and exhaust appear to be the same manifold, so how hot should that be?
I bought a cheap autozone 100-250 degree temp guage and will thread that in where my factory sender is. I will also try to borrow a friends l/R thermometer.
I removed the engine pump and it looks fine, however there is rub scars on the cylinder sleeve that shows a water pump did rub at one time. I hope that is not going to spell compression leak later down the road, hopefully the cylinders are thick.
