OK, I am having trouble getting water to the engine. Tested everything and think I have found the problem. After putting a new impeller in the raw water pump I can blow through it both ways with no resistance, even when I spin the impeller shaft. There are no leaks in the housing. I looked but found no scoring inside, I am stumped.
This is my problem right?
Thanks for you input.
