Re: adjusting valves
Well, what are we working on ? Anything with adjustable hydraulic lifters
I think these guys have been in the bilge too long inhaling those rotten old gas fumes
---> Just joking a little fellas ---> they are spot on.
If the lifters are new / good used ---> place in a container so the lifter is covered in oil and use a push-rod to pump the lifter up ----> when it don't pump any more it is done.
I will skip the cold test stand procedure as they have covered it.
Hot adjustment ---> engine and oil must be at normal operating temperature so all the parts are hot and expanded / stretched fully. If one of the rockers have been clacking when warn then it should be clacking by now.
Remove valve cover and install rocker clips to keep the oil from squirting out the top of the rocker arm all over the engine ---> do one side at a time unless you are quick ---> loosen all the rockers arms one at a time while the engine is running until you hear a clacking then down to no noise ---> if they were out of adjustment the engine should be running much smoother now ---> one at a time adjust the rockers down to engine specifications a quarter turn at a time ----> this may cause engine to run rough until the lifter bleeds down.
When finished check gaskets and install rocker / valve covers.
If something is still clacking on and off ---> you need to replace or clean lifter / lifters are cheap and not worth the time and effort disassembling and cleaning.
I remove the rocker arms and remove the push-rod to check for wear on the push rod ends and for bent push rods --- if unsure about a bent push rod roll them across a flat surface ---> the ends will wear and you can tell by the pitting and a larger opening than the ones with less wear or a new push rod ---> I use chrome molly push rods and they last a long time.
This should be a breeze as the engine is only running at 140-degrees and the exhaust is cool to the touch if the cooling system is working right
Happy boating
OFM
___________________________________
"If the boat is not sinking or on fire ---- Relax."
