Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Removing prop and stern drive.
  • Removing prop and stern drive.
    Hello again forum. I have a replacement stern drive for my boat. I will be taking it into a Marine shop for a going over and for a replacement of that "knuckle" component. So, I need to get my old one off. I am not having anyluck getting started. Do I work my way from the prop and go up?
    I can't even seem to get the prop off. I have remove the bolt that is through that cone part on the back of the prop. SHouldn't it come right off?
    Re: Removing prop and stern drive.
    The cone unscrews as well. Standard counterclockwise. stick a screwdriver through the hole in the cone. Prop will slid off.
    Knuckle, Ujoints?
    Just need to remove the upper gear box.
    Have a look at this thread.
    http://forums.iboats.com/showthread.php?t=309095
    '88 Baretta Success 200
    Volvo Penta AQ260/275
    '96 Weeres Suntanner 24
    '01 90hp Johnson
    • #3
      Here is a link to download the manual for your drive. There are instructions to remove it. I read it, and not sure I could take off a drive following those instructions, and I have removed hundreds of them.
      http://www.4shared.com/file/51930153...ce_manual.html
      Maybe thise pictures will help.
      Don S.
      Please, no PM's (Private Messages) regarding boat/engine problems.
      That is what the forums are for.
      Only forum/moderator issues will be answered in PM's.
      • #4
        Thanks Don, I REALLY appreciate the help....I have done the steps, but I think that if I hit the pins TOWARD the steering fork, they will hit the fork before they come out....I was thinking I needed to remove the fork somehow...am I still missing something...?
        Thanks
        • #5
          Like I said in one of the pictures. Turn the steering all the way to one side.
          You may only have one pin clear, but then just turn the steering the other way. They do clear. Disconnect the helmet first.
          Don S.
          Back to Top
