Re: mercruiser spark plugs ! to change or not to change, that is the question !
I replace mine usually every 2 years. If I notice any improvement in how it runs, it tells me I was overdue for a plug change. Thats just me and my slightly excessive repair/replacement schedules though. At 5+ years old, those plugs would have been in the trashcan at first oppertunity. I'd also pop the distributor cap and give it a good looking over, and inspect the plug wires for any signs of burns or cracks. Any damage or signs of excessive wear and those parts would be replaced. Also, if you've not done so recently, the fuel filter should be replaced. I do those every year.
As for plug type and gap, I've had good luck just using the Merc reccomended stuff. If its not marked on the engine somewhere, then the manuals are probably available in the sticky at the top of this forum.
