can anyone tell me the torque for the head bolts on a Mercruiser 470 3.7 1977?
S Sisshare Recruit Joined Sep 3, 2009 Messages 3 Sep 3, 2009 #1 can anyone tell me the torque for the head bolts on a Mercruiser 470 3.7 1977?
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 70,526 Sep 3, 2009 #2 Re: Mercruiser torque on head bolt 3.7 470 Ayuh,... It's in the Manual,+ the Manual is available up in the Adults Only section, I believe...
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,111 Sep 3, 2009 #3 Re: Mercruiser torque on head bolt 3.7 470 head bolts. 55,90, 130ft/lbs(final) and in this EXACT PATTERN exaust side 10 6 2 4 8 9 5 1 3 7 intake side
G gettin'even Petty Officer 3rd Class Joined Jul 28, 2009 Messages 93 Sep 3, 2009 #4 Re: Mercruiser torque on head bolt 3.7 470 Bt Doctur said: head bolts. 55,90, 130ft/lbs(final) and in this EXACT PATTERN exaust side 10 6 2 4 8 9 5 1 3 7 intake side Click to expand... Correct info. ALSO......very important to bring engine to operating temp, then let cool . THEN, retorque to 130 ft/lbs. The manual cautions against not performing this final retorque.
R rodbolt Supreme Mariner Joined Sep 1, 2003 Messages 20,066 Sep 3, 2009 #5 Re: Mercruiser torque on head bolt 3.7 470 manual also explains how to properly align the head to the block. failure can cause oil leaks or intake manifold breakage.
