StevNimrod
- Dec 13, 2008
- 343
I'm trying to get a 383 running on the ground before installing it in the boat. It sounded simple enough but I can't get the thing to start.
If it matters, it's a Merc setup similar to the 5.7 Gen +, but stroked.
I had a machine shop put it together and they adjusted the valves. Also, I'm running an Edelbrock 1410 carb with the out-of-the box needles/seats.
What I've currently done is set the timing (all different ways imaginable: finger over the hole, pulling #1 spark plug and spinning cap until there's a spark, etc.), then hooked up the ignition coil (two grey wires to (-), three purple wires to (+) and a jumper wire from coil (+) to battery (+)). Carb idle mix is set to 1.25 turns out. Ground stud on engine block to battery (-), starter (+) terminal to battery (+) and a remote start switch hooked up between the starter (+) and start terminal.
If I give the throttle lever a few pumps I see a consistent stream of fuel.
When I go to turn it over, the motor turns over but just won't fire. It almost acts like a motor does when you try to start it without the kill switch properly hooked up.
Any suggestions on what to try to get this thing to fire?
