Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
350 Chevy Small block starting problems ***please help!****
  • 350 Chevy Small block starting problems ***please help!****
    Hello....I have a frustrating issue. Just bought a 91 commander jet boat with a 350 chevy small block. I replaced the battery, battery cables, starter and the spark plugs. It started up just fine, ran it on the lake for about 20 min then all of a sudden the engine died. I started it back up and the engine sputtered, then died again. I eventually got back to shore and now the engine doesn't even start up. It cranks, but won't fire. It has gas in it, fuel is being squirted into the carb so there is no issue there. Spark plugs are fine. I even replaced the starter key ignition switch. One problem I was able to find was I had a dual point ignitor, but one side would only spark. I replaced it with a Pertronix electronic ignitor, thinking it would be the issue. Now when I crank the engine, it will turn over, but as I let go of the key, it tries to fire. I did the spark test, and as I'm cranking the engine there is no power going from the coil to the distributor, but as I let go of the key, there is a spark from the coil to the distributor. I even replaced the coil also. Tried using Engine Start with Ether.....still not firing up. Do you guys have any suggestions? LOL...I'm ready to take it to a shop.
    Re: 350 Chevy Small block starting problems ***please help!****
    Lose the ether or lose your motor. You don't need it. Check for 12v at the +side of the coil, key on engine off. If you do, recheck the instructions on how you wired everything. Could be you have something wrong in your installation of the new distrib.
    • #3
      Thanks for your reply. But it was doing this before I put the new ignitor in. I ony replaced it after it had died on the lake. I'll give it a shot though.
      • #4
        I have seen this before, A wire cold have been geting a cross feed 12V during cranking and now it isn't. Automotive startors have a terminal on the startor to give a full 12V while cranking and bypass a resitor. An easy check is to hook a jumper wire from known 12V to the coil and see if it starts, just know you will have to pull the wire off to stop the engine. If this gets it see if the startor has an R and an S terminal , I belive you would want to run a wire from the R to the B+ on the coil. If you really want to do it right put a diode in line to prevent back feed. Good luck
        The nut that fails the most is the one behind the wheel
        • #5
          I just checked and only 2.85 volts was coming out. Any ideas what the issue could be now? I'm wondering if the ballast resistor is causing this problem because I put in the pertronix electronic ignitor....or I just wired it wrong....
          • #6
            As long as your coil can take a full 12 volts get rid of the resistor, it's only there to protect the points. Just make sure it's 12V while cranking.
            • #7
              Pay close attention to your wiring instructions and make sure the 12 volt source you are using is switched at the ignition. Don't know what power package you have as lots of the boats of this size use chebby's, so I can't help you with the coloring of the wires.
              • #8
                If memory serves me correctly.........the ballast resistor is not needed with the Pertronix ignition.
                '84 Grady White Offshore
                350 Mag w/ Vortec Heads
                Alpha 1 Drive
                • #9
                  I just unplugged the wire from the ballast resistor to the + side of the coil. When I turned on the ignition, it shot up to 12V which was good. The engine cranked, but still wouldnt fire.
                  I'm just so thrown back as to why it ran for 20 min perfect, died on the lake, started back up, died again. When I got home, it wouldn't start up at all. Checked the dual points and only one was sparking. Took that out and replaced it with an electronic ignitor. Still doing the same thing.....not firing up.
                  • #10
                    Did you possibly kill the coil????
                    1987 Wellcraft 23' NovaXL
                    Mercruiser 260/Alpha I
                    • #11
                      Ayuh,... Is there 12Vs at the (+) terminal of the coil,.. While it's Cranking over,..??
                      There should be a wire from the starter that supplies the coil,.. While Cranking on the starter,.....
                      It's the small terminal on the solenoid, away from the block...
                      • #12
                        No...it did this when I had the old one, and I replaced it thinking that could have been the issue. But no....still not starting up.
                        • #13
                          Here's what happend. The voltmeter guage on the boat would read about 8-10volts when I turned the key without cranking the engine. I unplugged the wire going from the ballast resistor to the + side of the coil. Now it's reading 12V when I turn the key on. I used my volt reader to see how much was being put out at the + end of the coil while being cranked and it was only showing 2.85 with the ballast resistor plugged in. This morning I unplugged the wire going from the ballast to the + end of the coil. Didn't check what the reading was with my volt reader, but it still didn't fire up. It's doing this thing where the engine will turn over, but after I let go of the key, it sounds like it's trying to fire but doesn't. Like it's firing at the end and not at the beginning.
                          • #14
                            Ayuh,..... Your Wiring is AFUp...
                            The only thing the resistor is supposed to be resisting is the Coil... You're showing it on the Voltmeter...
                            The last line of my previous post deals with Just That....
                            • #15
                              Thanks. I really appreciate the information on this. So is there a way to fix this issue?
