I have a 1989 Sea Ray with the Mercruiser 4.3 while running about 20 MPH the engine raced shut it down and in an attempt to restart the only thing the starter would turn was the flywheel.
After getting the boat on the trailer I could spin the flywheel in forward using the prop but the motor wasn't turning. Pulled the outdrive and the flywheel is loose in the housing. Wondering if the bolts can snap off or if the crank broke off??
