Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Hot alternator on Mercruiser 5.7
  • Hot alternator on Mercruiser 5.7
    Can anyone help please? The alternator failed on my Merc 5.7 (2003/4). Next morning it was found to be very hot after an overnight stop. Yard replaced it, but after about 4 hours use (2 cruises) it seems to have burnt through the drive belt. Fitted new drive belt, 10 mins running and the new alternator is now very hot. The bearings are turning freely, so I suspect some kind of electrical fault on the boat. Any advice greatly appreciated.
    Re: Hot alternator on Mercruiser 5.7
    does this mean that it was sitting, all night long, and it was hot in the morning, before running?
    • #3
      Ayuh,... Sounds like you have a Dead Short somewhere, Inducing a Full Load condition on the Alt....
      Start unhooking systems til you find the Fault...
      • #4
        Yes Flargin, it was sitting all night, we used domestic items (lights, fridge) only, and it was hot in the morning before running. I had turned the ignition key for a moent, but as the battereis were flat the engine did not turn over.
        • #5
          Originally posted by Bubba1235
          Have you checked the pully alignment with a straight edge? Eyeballing it is not good enough.
          Hi Bubba 1215; I will try to check pulley alignment, but it got hot whilst stationary.
          • #6
            Heck with alignment , just like Bondo said you have a serious Short !
            Start tracing back one at a time. I would suspect you should feel a warm wire to something with that much current being drawn.
            • #7
              I would figure it out, or pull your battery why you are not working on it, and pull your shore power, if you have it. don't take any risks that the short will overheat..
              Back to Top
