Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Outdrive oil type...Mercruiser vs walmart brand
  • Outdrive oil type...Mercruiser vs walmart brand
    Is there any difference between the Walmart brand Gentech and the Mercruiser brand? The price difference is significant, 14.00 vs 3.00.
    paul
    Re: Outdrive oil type...Mercruiser vs walmart brand
    I have moved this over to the I/O section as it is specifically asked about an outdrive . . .
    I was tempted to lock it as these threads almost always become a peeing contest However . . . since I don't recall a specific question about Gentech, maybe it will be valuable. If the flames start, I will pull out my peeing stick and quench it in a heartbeat DonS may lock it even sooner. Good luck!!!
    Torque gets you there. Horsepower gets you there in time for dinner.
    • #3
      It has always been my belief in life..."You get what you pay for...." buyer beware....
      1984 - S2 Yachts - 23' Tiara Continential - 260 mercrusier - alpha 1 drive
      • #4
        as long as its gl-5 certified, you'll be fine.
        1984 Cobia Charger, 120 Mercruiser/Alpha 1
        • #5
          paul
          Do you mean "Supertech?" And you are talking about the outdrive oil, and not the engine oil... correct?
          I use the Supertech ENGINE oil without any qualms in most of my engines - car or boats.
          For the OUTDRIVE, I spend a little extra and use the Mercruiser High Performance lube. The "green stuff." I suspect the Walmart brand of oil is the same as the "regular" Mercruiser lube - if it is light brown or honey colored it is the "regular" stuff. I recommend the green stuff. (How's that for scientific description? )
          • #6
            I have had good luck running the Pennzoil premium marine gear lube...5 bucks a quart. I change it twice a year though.
            1981 ChrisCraft 210 Scorpion K,175 Johnson SeaHorse
            • #7
              When it comes to the outdrive lube I use the Merc High Perf. They designed the outdrive. Comaring price of outdrive replacement to $10 more for a quart of lube I wouldn't chance it.
              • #8
                Is Merc high perf gear lube+ gl-5 certified? I don't see it on the bottle or in the merc accessories guide saying it is, just curious.
                James
                • #9
                  The Walmart typr that I recently used was the green type which I have usually seen from the "better brand lubes" or even sythetic or synthetic blend.Charlie
                  • #10
                    I run the Merc HIPO Fluid.
                    90 Chaparral 2150SX 350 MAG Alpha 1
                    Vortec Heads, LT4 HotCam Upgrade
                    GM BowTie 1.6 Roller Rockers
                    Edelbrock RPM Air-Gap Intake
                    Edelbrock 600CFM Marine Carb * New MPH* 65.2
                    Laser II 21 Prop 5400 RPM's Corsa Exhaust
                    • #11
                      Assuming you change your outdrive oil once a year, you'll save about $11 per year on an Alpha, and about $33 per year on a Bravo.
                      Have you priced drive repairs or replacements lately? Figure that you're going to need somewhere in the neighborhood of a minimum of 50 years of savings if the cheaper oil causes you ANY type of drive problems.
                      Supposedly the Merc stuff can hold a substantial amount of water (lots of detergents maybe?) and still provide adequate lubrication in case of a leaking seal. Guess that's what bullet #3 is about in this Mercruiser propaganda: http://www.mercurymarine.com/otherpr...gearlubehp.php
                      I run the Merc stuff in mine, figure $30/year is worth it just to not have to worry about it enough to ask the opinion of a bunch of yahoos on the internet who you have no idea how much they know!!!
                      Any opinions expressed above are worth exactly what you paid for them!
                      • #12
                        Well I went to the dealer today and the Merc stuff costs 16.50 a qt. if anyone is interested.
                        How much does the outdrive hold? Thanks
                        paul
                        • #13
                          Approx a quart and 1/4 to a 1/2.get 2 quarts and you are covered.charlie
