My 1991 Mercruiser 3.0 will no start, but cranks over (now that I've replaced the starter ). I yanked the first plug and held it against a good ground while cranking the engine and I don't have a spark.
My plugs are brand new. The spark plug wires look fine, and electrical connections seem good and tight. The distributor cap had some moisture under it when I pulled it out of storage a few weeks ago, but I left it off for a week (while replacing the starter), and cleaned all of the contact points and the rotor tip.
I'm not seeing much in the way of troubleshooting in the service manual. In your guys experience, are there any easy tests to be done on the coil or distributor? If not, what is the most likely culprit?
