Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Tilt Trim oil for mercruiser 140
  • Tilt Trim oil for mercruiser 140
    My boat is a sun ray(80s) tri hull with a mercruiser 4 banger engine and alfa 1 outdrive(i think) says 140 on it!! The tilt trim is the power trim double hose. My book says it takes 5w-30 oil. Can I use 5w-30 synthetic? or even 15w-40?
    Thanks
    ps keyboard broke
    Re: Tilt Trim oil for mercruiser 140
    You can actually use just about any petroleum based oil.
    I use auto trans fluid because it's red and leaks are easier to identify.
    Regards,
    Rick
    1987 FourWinns 211 Liberator, Formerly OMC 460 King Cobra powered, now powered with a 1997 Mercruiser 7.4L Bravo III
    No water"foul" were chopped up when test driving my 211 Lib except the ones I ran over intentionally! All posts are created using LINUX!
    • #3
      You need to see what color fluid is in the trim system already. If it's red then you can use Dextron ATF. If its clearish/tanish then its tilt/trim fluid.
      just because you found it that way does not mean it is supposed to be that way.
