Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Mercruiser 888 Tilt / Trim Issues
  • Mercruiser 888 Tilt / Trim Issues
    Symptoms: In neutral, forward or reverse (engine off, on trailer, etc) I can grab the skeg and lift the outdrive up by hand with very little hydraulic resistance. I can then lower it back to the original position by letting it down (again, by hand).
    On the water, I can put it in reverse and it creeps up - it doesn't pop up. Of course, I didn't rev it up to see if it would pop up.
    In forward, it creeps towards full trimmed down position (slowly). I have to tap the trim up switch from time to time to keep the bow from digging in as I cruise.
    History: Previous owner had replaced all exterior trim hoses. I have not checked for water in tilt / trim fluid. I don't have gauges set up to perform tests of the hydraulics as denoted in the Mercruiser manual.
    My question to those experienced is this: Should I start by tearing down the cylinders? I suspect bad or rust covered check balls and springs in the cylinder piston assy. The cylinder ends have marks suggesting that they have been disassembled before.
    I'm okay with working on hydraulic systems, but I'm not familiar with the construction of tilt / trim cylinders.
    Guidance and help is appreciated.
    Re: Mercruiser 888 Tilt / Trim Issues
    Do you have the service manual for the drive? It's available in the Adults only Sticky.
    I haven't done it, but I would bet the procedure is in the service manual.
    20' Suntracker Pontoon
    • #3
      Surfdancer, It sounds like who ever changed out the hoses didn't refill or bleed the system correctly. Refill the tank (unit down) with ATF and operate your trim several times to remove air. Look for ATF leaks while you operate them. Unless you struck something it's not likely you need to rebuild rams. The rams/cylinders are simple to rebuild once you get them apart. THAT'S the hard part. Don't put your rams into a vise... smashing the tubes will ruin them.
      • #4
        I'll give that a try...
        Thanks!
        • #5
          Thanks!
          I have a 75 888 drive, I just replace the High pressure line from the pump to the diaphraghm and I can get it to trim all the way up but only down half way. I have filled it and checked it every time it was all the way up. Does the bleed process take a long time? Or do I have another issue?
          • #6
            I saw there is a Service manual out there can someone please repost that link??!!
            • #7
              Welcome to iboats lurch, you need to start a new thread of your own with your questions and not dig up 4 year old threads out of the archives.
              Don S.
              Please, no PM's (Private Messages) regarding boat/engine problems.
              That is what the forums are for.
              Only forum/moderator issues will be answered in PM's.
              Back to Top
