I have a strange question. I'm new to Mercruiser I\O's but I recently purchased a boat with a Mercruiser 165 inline 6. I'd like to convert it to a closed cooling system. I've done a little looking around at the various configurations and the 470 parts look like they will fit the larger 165 manifold.
A buddy of mine has a coolant tank, thermastat housing, and a 4" heat exchanger from a 470 (if I can make them work I can do it CHEAP). The main difference I've found between the two is the 470 includes the manifold in the closed loop so the location of the raw water introduction into the exhaust is back at the riser rather than at the front of the manifold. Do you know of any other differences or problems that I need to look out for? Is the heat exchanger big enough to work on the 6 cyl? I know it will take a different gasket at the riser but the rest of it seems to be a workable scenario. Have any of you ever seen this done successfully?
