Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
How do I bleed my trim cylinders?
  • How do I bleed my trim cylinders?
    I was just wondering how it is I should bleed my trim cylinders. The boat hasn't been used in around 8 years, and the cylinders are only connected to the lines and not the out drive itself.
    Re: How do I bleed my trim cylinders?
    Please give us your year and make of outdrive. That info is really needed to help you easier. Add your boat info to your signiture line so you dont have to enter it every time you post.
    1994 Crownline 182BR w/4.3LX 4bbl Alpha 1 gen 2
    2007 Dodge Ram 1500 SLT w/5.7 HEMI
    2004 Chevy Tahoe w/5.3
    1970 Chevelle SS 396-OK its the 18 year old daughters car but hell its fun to drive!!
    • #3
      If its mercruiser they say just up and down a few times while keeping an eye on the fluid level.. Eventually all the air will be removed.
      90 Chaparral 2150SX 350 MAG Alpha 1
      Vortec Heads, LT4 HotCam Upgrade
      GM BowTie 1.6 Roller Rockers
      Edelbrock RPM Air-Gap Intake
      Edelbrock 600CFM Marine Carb * New MPH* 65.2
      Laser II 21 Prop 5400 RPM's Corsa Exhaust
      • #4
        for me, that's the alternative method to use. there is a bleeding procedure that is to be used if the above method don't work out. also for me. in both methods. the trim rams need to be disconnected from the drive at the aft pin. both methods require you to hang the rams vertical too from a quik read of the s/m that covers my 1975 system.. of course we still don't know if it's even a mercruiser.... so anything said, could be null and void, depending on what the op has..
        'Lime Time'
        1975 AristoCraft Nineteen
        Mercruiser 165hp (chevy 250 L6), MC-1 drive
        • #5
          If the lines have never been disconnected they may not even need to be bleed.If you don't have puddles of fluid anywhere you should be able to just run them up and down a few times.They will bleed themselves as the fluid passes through the pump if there is any air in the lines.Just make sure you keep the pump full!
          sigpic
          23' Nordic Viking
          500HP BB Chevy
          TRS Drive
          Back to Top
