Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Block Heaters and Winterizing questions...
  • Block Heaters and Winterizing questions...
    Hey Guys - I have been reading a bunch of these engine heater / winterizing forums and I have not seen any mention of freeze plug style block heaters. I have a Crownline 1995 Mercruiser 350 w/ a Bravo One. Does anyone know if this motor has the normal freeze plugs that an auto version would have? If so - can I not just use a $30-50 block heater for a Chevy 350?
    I live in E. TN (rarely dips into the 20s deg F) and I usually get out at least once or twice a month in the winter. I plan on keeping my boat in a wet slip with power access. I also plan to drain the main plugs on each cold weather visit but would like a little extra protection. My other option it seems would be one of the Wolverine style silicone pad heaters. Has anyone used these on this style motor? If so - Which model / wattage and mount location?
    Let me know what you guys think. Thanks for all the pros who take time to help the rest of us out!
    Thanks!
    RockGeek
    therockgeek@excite.com
    RockGeek
    1995 Crownline 225 CCR
    Mercury 350 Magnum Bravo One
    Re: Block Heaters and Winterizing questions...
    1. There are no Freeze Plugs on a SBC. Those are core plugs used in casting the block, nothing to do with freeze protection.
    2. Core plags are the same size on all 350's, Marine are usually brass.
    3. I think the whole plan is a really bad idea.
    The last time religion controlled the world it was known as the Dark Ages
    • #3
      Hey Bomar - thanks for the input. Do you recommend any other methods for keeping the boat usable year round? I know there are quite a few people who keep their boats in wet slips through the winter in this area. Are they all just risking freeze damage?
      Thanks,
      RockGeek
      RockGeek
      • #4
        Yep.... there's no such thing as a freeze plug.... that a common mis-used word.... and a common mis-used idea.
        The only thing you really can do is to make sure you drain EVERYTHING after you go out every time.
        If you really want to do a lot of winter boating, then converting the engine to closed cooling will help some, as it's less things to drain.
        just because you found it that way does not mean it is supposed to be that way.
        • #5
          There are heaters for the oil, you stick down the dipstick, had them in Alaska.
          However you could keep your boat in a heated garage.
          There are other ones do a search i posted on them a while back.
          Good luck
          " The Chief Has spokin "
          1986 Citation 19' 140 merc motor transplanted Sept. 2008. Stringer drive.
          1976 Arrowglass couger, 76 Evindrude 70 hp.
          1970 Aluminum jon boat 3 hp air cooled sears out board
          Be good, be happy, treat people as you would want them to treat you, for tomorrow is promised to no man.
          • #6
            Anything that relies on power is a bad idea.
            Power goes off, and you are SOL.
            Same goes with the heated building idea, power dependent.
            As Jason says, drain it (doesn't really take that long)...the only safe way.
            Engines and manifolds are expensive.
            • #7
              Ayuh,...
              By their very nature, a coreplug mounted block heater Won't work that way...
              They are Immersion heaters,... Without Water surrounding the element,...
              As soon as you power it, It'll burn up,+ Quit...
              • #8
                i use my boat in the winter i just pull the plugs in the manifolds, open the drains on the block and pull the hose off the power steering cooler after every trip i usually do it at the ramp so on the way home the movement may help it drain better.it only takes a few minutes
                1996 19 ft Stingray 586zp alpha one 4.3L SOLD
                1988 Sweetwater pontoon 70 Evinrude
                • #9
                  I also drain it every time after i flush it. When it's cold outside.
                  I use the boat in saltwater.
                  Like Bondo says air can't freeze.
                  After 2-3 times i bet it won't take you 5 minutes.
                  I just leave the wrench on the boat with the plugs when i do it.
                  Takes maybe 5 minutes to put the plugs back.
                  • #10
                    Here it is again.
                    http://forums.iboats.com/showthread....lock+heater%2C
                    • #11
                      Ya, I'm going to echo what everybody's said
                      bad idea
                      A) the block heaters are designed to heat the coolant and have the coolant heat the the engine... Without the liquid thermal coupler, your block heater will likely heat up to the point where it blows.
                      B) Relying on electric heat to prevent your block from cracking is a bad idea. Power faillures happen and when they do, your screwed.
                      I had this thought process before, and what I wanted was a magnetic heater that was only about 30 watts. Then I was going to use a computer UPS aswell. 30 watts directly on the side of the block would buy you like a 10 degree cuision from freezing. And at only 30 watts, a halfway decent ups could buy you 5 hours at least of power should the power go out.
                      But.... that thought of "air can't freeze" really made that whole idea pointless, so I drained my block , and now there is nothing to worry about.
                      • #12
                        FWIW, I kept my boat in a wet slip the past 2 winters in northern Maryland. I wanted to have the ability to use her on nice days so I installed 2 marine bilge heaters (Boatsafe). After the first couple cold days, I got nervous and winterized anything containing water including the engines because, as Bomar pointed out, a power outage lasting more then a couple hours on a cold day could be very, very expensive.
                        Draining and re-winterizing isn't too difficult and definitely worth the time and cost compared to a new engine.
                        "Winter Dream"
                        Silverton 34C
                        White/Green
                        Wellcraft 23 Nova XL
                        Lowe 1448 BigJon
                        w/Evinrude 25HP
                        • #13
                          Thanks for putting up with the Newbie!
                          Ok - so no go on relying on a heater. I am certainly convinced of that. Can I do this drain procedure while in the water though? If the boat is in the water there is always going to be water in some part of the engine - right? Do I also not necessarily need to flush and fill with anti-freeze?
                          The whole idea is that I would like to leave the boat in the water and not have to haul it around or take up space in my driveway. Am I just going to have to forget about that at least for the winter months?
                          Thanks again for everyone's input. I do appreciate it.
                          RockGeek
                          • #14
                            They make block heaters with that much power?
                            sigpic
                            Nothing is so broken that Government can't make it worse.
                            • #15
                              Well, yeah...
                              As Bondo pointed out, they are just immersion heaters (like the element in your electric water heater) and no matter what the wattage, no water surrounding it, the elemnent burns up.
