Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
No power to fuel pump on 1994 4.3L V6 Mercruiser
  • No power to fuel pump on 1994 4.3L V6 Mercruiser
    I am trying to troubleshoot my starting problem. It was running fine about 2 months ago before TS Fay came through here. This is the original 1994 Mercruiser 4.3L V6/Alpha One combo in a 1994 Wellcraft Excel 20SL. Engine S/N is OF272108.
    The fuel pump will not run, the accelerator pump is dry and the fuel line above the pump is dry. I did get a fair amount of fuel from the line that runs from the tank to the bottom of the pump. The engine will crank and will fire if "hand fed" a small amount of fuel directly into the carb (I know - dangerous thing to do. I used a very small amount, and yes, I did replace the flame arrestor before cranking it over). Oh yeah, fuel tank is over 3/4 full as well.
    Using a DVM, I have checked the wiring at the pump connector. I have continuity through the black wire to ground, but no voltage through the purple w/tan stripe wire, with the ignition on. I cannot locate the other end of the purple w/tan stripe wire after it disappears into the wrapped wiring harness behind the carb.
    Electrical seems to be generally OK as the engine will run when it gets fuel as noted above. I have checked every connector and splice I could find to make sure things are seated (I did find and repair one bad connector to the bilge pump, though). Oil pressure registers on the dash gauge when it tries to run.
    Anyone have any ideas? I'm not convinced yet that it is the pump itself until I can confirm that the power is getting to the pump.
    Thanks!
    -Mike-
    Re: No power to fuel pump on 1994 4.3L V6 Mercruiser
    Just above the oil filter (non-remote filter) is an oil gallery fitting. There's a tee piece with the oil pressure sender and an oil pressure switch. The supply for the fuel pump is fed through that switch. It's only closed when there is oil pressure. The way the pump gets power when cranking is through a terminal on the starter solenoid.
    To test the pump without the engine running you can temporarily jumper across the oil pressure switch. Those switches have been known to be a problem with corrosion. Many 4.3 owners, not knowing the dangers, have jumpered them out permanently.
    Chris........
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    The world takes on a whole new perspective when viewed from 100’ below.
    1972 Bertram ‘Bahia Mar’ 20
    2006 Mercruiser 4.3MPI (0W617679) w/Alpha One Gen II (0W829301)
    (Original - 1972 '165' In-line 6. Previous - 1994 4.3LX)
    • #3
      Thanks! I didn't locate those connectors - I was focused on the top end. I'll give that a try tomorrow, and post the results here.
      -Mike-
      • #4
        Here is the fuel pump wiring diagram. It may help you understand how and why it works.
        Don S.
        Please, no PM's (Private Messages) regarding boat/engine problems.
        That is what the forums are for.
        Only forum/moderator issues will be answered in PM's.
        • #5
          Thanks, Don S! That clarifies what achris sent. I'll be checking back on these this afternoon. I'll post the results here when I return.
          -Mike-
          • #6
            OK - first, I tried the jumper across the oil pressure switch with no change in results.
            Second, I traced all the connections in the schematic down to the terminals and found no problems with pinched wires, corrosion, loose connections, etc., other than two exceptions: 1) the red/purple wire that is supposed to feed the starter solenoid does not exist in this harness, and my solenoid does not have another post to connect anything to, either. 2) I have an additional red cable running from the battery post on the starter solenoid up to a 50A breaker mounted on a bracket on the intake manifold alongside the start slave solenoid. This cable is slightly smaller than the red battery cable, but much heavier that the other wires in the harness. The output of this breaker uses a heavy red/purple wire that disappears back into the harness and I presume feeds the red/purple common line that goes back to the alternator.
            My next thought is to use a splicing connector and tap the purple/yellow wire from the fuel pump and connect it directly to the battery to see if the pump will run.
            Any other thoughts? You guys have been great and I really appreciate the feedback. Although the solution hasn't been found yet, you've been very helpful!
            Thanks!
            -Mike-
            • #7
              Don't ever do that on your boats wiring. That would be the weak spot in the wire and would eventually corrode and break.
              Just unplug the connector on the pump and use a couple of jumpers from the battery to test the pump.
              You just push in on the wire on the connector to release the connector.
              Don S.
              • #8
                I have not seen a post on it yet but did you check all fuses?
                • #9
                  Yeah, I wasn't crazy about that idea, either. I've seen plenty of wires corrode internally from that kind of break in the insulation. I was going to hit it with some anti-corrosion goop I have and wrap it with some high-heat electrical tape. Better not to do it at all, though.
                  I'm off to the garage to build a couple of jumpers....
                  Thanks!
                  -Mike-
                  • #10
                    Funny, now that you mention it, I haven't even seen a fuse. No fuse block or inline fuses, either. Just the one master 50A breaker. Interesting.....
                    Thanks!
                    -Mike-
                    • #11
                      The only fuse you will have is one under the instrument panel. But, if it blew, you wouldn't have spark either. Since it will run if you get gas to it, you have spark.
                      When you check the pump, if it doesn't run, DO NOT start beating on it or holding the power to it for long periods of time. It may just be locked/gummed up from sitting.
                      Don S.
                      • #12
                        OK, the pump works!
                        I ran jumpers straight to the battery and to ground and got a solid flow of fuel from the pump. I had the fuel line disconnected and in a can so I could be sure there was fuel instead of just hearing the pump run. Pulled the jumpers off and re-connected the fuel line and the connector to the pump and turned the key on. No noise from the pump. I cranked the engine and it started right up and ran for about a minute at idle, then stalled and would not restart. Just used up the fuel in the line, I'm sure. Repeated the experiment and got the same results. Pumps with jumpers. Engine runs for a minute after re-connecting it all, then stalls. No noise from the pump while connected to the harness.
                        Also jumpered the connectors for the oil pressure switch one more time to be sure and still no noise from the pump, so I believe it's not a bad pressure switch. Actually, if I look at the schematic, I don't think the pump relies on the pressure switch for power anyway, and I seem to remember the pump running as soon as I turn the key to "ON" (but not to "START") and then it would stop in about 5-10 seconds, presumably because it reached adequate fuel line pressure to start the engine and keep the float bowl full.
                        So, I'm back to the wiring harness. How much voltage should I be able to read at the pump connector? A full 12v or something less? I'm going to do as many continuity checks and voltage checks as I can before I give up and call my mechanic. I'm just going to hate it if I have to pay him $250 to find a $20 part has gone bad. :>)
                        Many thanks again!
                        -Mike-
                        • #13
                          The pump will get a full 12 volts under the proper circumstances. If it is carbed then the pump should not turn on with the key. The pump will only get 12 volts when the key is in the START position during cranking or when the engine is running and the oil pressure safety switch sees oil pressure and turns "on". This is how it works if wired correctly. You should be able to read the wiring diagram and see how it all connects.
                          You will never have power at the pump with just the key in the ON position (engine not running). However there should be 12 volts on one of the oil pressure safety switch terminals in this condition (key ON and engine not running). If there is power at the oil pressure switch then jumpering across those terminals should give 12 volts to the pump and it would start pumping (this could indicate a bad oil pressure safety switch). If there is not 12 volts at the oil pressure safety switch on either terminal then the problem is between the oil pressure switch and the 12 volt source.
                          The pump receives a full 12 voilts with the key in START position thru a bypass circuit. If the pump does not run when cranking then the problem is between the key and starter/solenoid or starter/solenoid and the pump.
                          2002 Bryant 188 Mercruiser 4.3MPI
                          • #14
                            With the key ON, you should get volts (all 12) at one of the terminals (purple wire) on the oil pressure switch. If you have that, then put your temporary jumper in place and see if it's still there. I'd be looking for a bad connection somewhere that has 12 volts there without load, but when the load comes on, the voltage drops away.
                            Check voltage at oil pressure switch without the switch jumpered, and then with the switch jumpered. If you don't have voltage there any time, then start working back towards the purple wire.
                            Chris...........
                            • #15
                              make sure your connecting a water supply if letting engine run, so you dont end up with a second problem.
