Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
estimated cost of starter replacement
  • estimated cost of starter replacement
    Hello everyone, I'm just curious what the estimated cost of paying someone to replace my failing starter. I know that the part is $170 but what can I expect to pay a mechanic to put it in?? Thanks for your help.
    1986 Cobalt 260hp GM 8cylinder
    1986 Cobalt 19br 260 GM
    2006 Honda Odyssey
    2004 VW Passat TDI
    Re: estimated cost of starter replacement
    All depends on how hard it is to get to.
    If a bolt breaks off or is rusted bad the engine may need unbolted and lifted up.
    I had that happen on a 4.3 engine in my last boat.
    170 is kind of high for the starter but not too bad. You can get one online for around 100 bucks.
    80 to 100 per hour is about normal labor charges around here...
    1981 ChrisCraft 210 Scorpion K,175 Johnson SeaHorse
    • #3
      Ayuh,...
      It depends entirely on How Much of your boat has to be disassembled to get To the starter....
      • #4
        This may not be the exact one you need but it shows you the price.
        They ship next day to Charlotte using UPS ground..
        http://www.ebasicpower.com/pc/MES531...lvo+GM+Engines
        • #5
          Thanks guys...my tech said he can get me one locally for $170 with a 5 year warranty..may let him do it just in case its the wrong one he can deal with it. The price on I boats for the Sierra is $174 plus shipping. Those little starters are like gold. I can't complain, I've owned the boat 3 years and thus far (prior to) have only put a few hundred in it (minus the cover I just bought).
          2006 Honda Odyssey
          2004 VW Passat TDI
          • #6
            I just did mine. Got lucky and found one on eBay for $50. The rear seat and two supports on both sides of the engine bay have to come out so you can lay down beside the motor. It is labor intensive and would cost as much in labor as you paid for the starter. It is not an easy job; but I enjoy doing all the work I can...
            1987 Wellcraft 23' NovaXL
            Mercruiser 260/Alpha I
            • #7
              Great, come do mine ;-).
              2006 Honda Odyssey
              2004 VW Passat TDI
              • #8
                I got stuck in a port 2 1/2 hours away one year when my starter decided to go south. Cost well over $300, plus a couple car rides back and forth.
                sigpic
                Nothing is so broken that Government can't make it worse.
                • #9
                  due to a manufactures design flaw that allowed the starter to sit on the stringer, motor removal was necessary to change the starter.
                  rusted bolts,corroded in place, broken bolts,room to access the starter ,and most likely 1 or 2 items i forgot all need to be considered when asking for a estimate.
                  NO PERSONAL QUESTIONS, THIS IS WHAT THE FORUM IS FOR.
                  • #10
                    ouch
                    sigpic
