Just curious.I've worked on gm engines for the last 20 years.If u look at a tbi system on a truck the injectors are sealed and if there ever going to leak are going to leak into the intake. The dist has a vent hole in the bottom plate with a screen over it.They use 14 psi of fuel pressure. I just don't c what all the fuss is over people using a truck tbi setup on there boats. U can get an external marine fuel pump that is rated for 14 psi. U can have flexible stainless steele lines made up that are rated up to 1000 psi or more
