Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
How do I tighten steering Linkage
  • How do I tighten steering Linkage
    Hi - i have a Donzi 212 bowrider with a 454 Merc and quicksilver - Steering has allot of play and I have to always move steering wheel back and forth to keep boat straight especially going slow
    any idea how to tighten steering up??
    Thanks
    Re: How do I tighten steering Linkage
    Ayuh,...
    There's probably Nothing wrong with the steering,...
    But,...
    You should look it over anyways,+ Inspect it for Slop in it's connections....
    Have somebody shake the steering wheel maybe a 1/8, or 1/4 turn, back,+ forth,.. While somebodyelse holds the outdrive from Moving... You crawl down into the bilge, up next to the Transom assembley, inspecting the connections from the outer cable housing to it anchor point,+ the inner cable to the tiller , or P/Steering unit, the Tiller's connection to the gimbel, etc...
    Then have the heartbeat shaking the steering wheel, Just Hold the steering wheel, while the other person Shakes the outdrive...
    Inspect All of the connections Again.....
    The most common spot for a Problem is the Tiller to Gimbel point.....
    Oh,... Btw,... Welcome Aboard to the forums here at iboats.com,...
    And,...
    Most All V-hulled boats tend to wander at Idle speeds,...
    Just correct less,+ Learn to live with it,...
    It's part of being a Boater,...... That Ain't no Car ya-know.....
    Back to Top
