chiefalen
- May 18, 2008
- 3,598
Hi all, here i am again asking for advise. Never easy to do.
Installed new used head, Ran great on the trailer in the driveway. No leaks.
Go out on the bay test run. No leaks all is well. Take off the valve cover, re-adjust the rocker arms, torque down the head bolts.
The head bolt starboard side first one closest to the transom strips out.
Water starts pis-ing out between the the head and the block.Still running good.
Come home, take off the head and the corner in cracked. Run all over and find a longer bolt about 1/2. Grind down the crack cause it lifted a bit.
Ok install the head with the longer bolt has enough thread at the bottom of the hole. Bolt holding good.
Small crakc on the back side of hole externally on the block, where the bolt screws in. Water seeping out. Very,very slowly.
No water coming out of the head gasket.
I am thinking am i done.
Can this be a job for jb weld.
Drain the block make sure it's dry sand it clean it with acetone?
Will it work?
Thank you all in advance for your best guess.
Will it work?
