Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Mods to a 3.0 140 hp mercruiser to pull a skier?
  • Mods to a 3.0 140 hp mercruiser to pull a skier?
    What can I do to a 3.0 140 hp mercruiser inboard to get more power or torque to lift a slalom skier out of the water?
    Thanks
    1990 Bayliner Capri 1850 BR - GM 3.0L Mercruiser Alpha One Sterndrive.
    Re: Mods to a 3.0 140 hp mercruiser to pull a skier?
    Either a bigger engine, or under-prop it so you get more low end, but less top end speed.
    The prop forum would be the best place to post your prop size question.
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      My 18' works just fine for pulling folks up and out of the water, I run a 14.5x19 Solas Rubex prop.
      The performance upgrade thought I too got early on was soon shattered by the fact that there's nothing out there. Nothing short of a cam, port / polish the heads, over bore the cylinders. At that point, you're looking at spending more than it's worth for the meager gains you would get out of our little 4 bangers.
      One of the big errors we make is thinking in terms of a car, the power band in a boat is totally different. From what I see it's much flatter in a boat than a car and a boat motor is meant to be run wide open if you want to go fast. Forget torque figures and realize it's all about how many horses you can crank out. For us, it's pretty much 140 and that's it.
      • #4
        ^^^^^Don't forget however,
        In a boat, just like a vehicle - "torque" is what gets you moving. HP determines how fast that movement will be....
