blackcat2008
- Aug 22, 2008
- 2
I am currently going through the process of running in a Mercury Magnum 350 mpi engine. My initial 2 or 3 trips were successful, however i have now uncovered a problem that is causing a headache.
The engine has recently developed an intermittent complete cut out and immediate switch off (no burbling or stuttering was heard). This has become more frequent during the most recent 2 trips. I have replaced the fuel pump relay as intitally i thought the problem was with this relay not continuing the fuel flow when taking over from the start up relay after 20 secs of running. The problem seems to be more frequent between 2500 and 4000 rpm, however it happens in differing rev ranges including tick over of around 1500 rpm.
The engine has only 3 hours on it, and i am yet to push the revs past 4000 rpm. One of my own thoughts are that it could be a built in 'safe running in cut out', however i would be surprised by this as it could cause a serious safety problem.
If anyone has an idea then it would be much appreciatred and save some head scratching.
