Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Mercruiser alpha 1 lube grease fittings
This topic is closed.
  • Mercruiser alpha 1 lube grease fittings
    94 alpha 1, There are 3 grease zerts on my out drive, one on each side for the tilt hinge and there is 1 on the right close to the back where it bolts to the boat, what does that grease, the gimble?, I grease it but do not know what it is greasing as I do not see grease coming out anywhere like on the hinges and didnt want to put too much without knowing where it was going, thanks
    Re: Mercruiser alpha 1 lube grease fittings
    Third 'zit' is for the gimbal bearing, inside the gimbal housing/bellows. We call them 'grease nipples'.
    I give mine a couple of pumps every 4 or 5 months.... Job done...
    Chris.........
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    The world takes on a whole new perspective when viewed from 100’ below.
    1972 Bertram ‘Bahia Mar’ 20
    2006 Mercruiser 4.3MPI (0W617679) w/Alpha One Gen II (0W829301)
    (Original - 1972 '165' In-line 6. Previous - 1994 4.3LX)
    • #3
      Fantastic thanks, I thought that might be it, I was just always told you had to have a shop pull the outdrive and grease it, that just makes my day Thanks again
      • #4
        Yes, the drive should be pulled regularly. If only to check inside the bellows. Also to grease the unis... At this age I'd be looking really closely at the bellows.... Turn the steering hard to port and look at the starboard side of the bellows... see any rubbing or wearing on the edges? Turn full starboard and look at the port side of the bellows. If you see any damage or wearing on either side then it's time for new bellows, before they go through. I've seen several of this era go like that...
        Chris...........
        • #5
          They're actually called "zerks"
          • #6
            They are actually called "grease nipples". I looked in my Websters and on the internet and couldn't find anything called a 'zert'....
            Chris..........
            • #7
              Most common name is Zerks.
              Also, do not forget to grease the splines in behind the engine on the drive shaft.
              From Wikipedia, the free encyclopedia
              Jump to: navigation, search
              Grease nipple on a bearingA grease fitting, grease nipple or zerk fitting is a lubrication fitting used in mechanical systems to add grease with a grease gun. The fitting is permanently installed by a threaded connection leaving a nipple connection the grease gun attaches to. By using the pressure in the grease gun, grease is added to the system through the grease fitting. Generally a spring-loaded steel ball is fitted to the internal side of the nipple inlet passageway to exclude dirt intrusion and function as a shutoff valve to prevent grease escaping back out of the nipple. The ball is almost flush with the surface of the nipple so it can be wiped clean to reduce the amount of debris carried with the grease into the bearing.
              In many modern applications however, they are falling out of use since it has been determined by wear analysis that each new grease injection usually contains abrasive contamination and thus service life is reduced compared to many "sealed for life" systems.
              The patent for the zerk fitting was granted to Oscar Zerk in January 1929
              • #8
                ok... you win... But I still call it a grease nipple.... Zerk is not a name ever used in Oz...
                • #9
                  I am woefully behind in greasing the coupler and gimbal zerks. The manual says 8-10 pumps once per year. Since I am several years behind any idea how much grease I should try to apply ??
                  • #10
                    Welcome to iboats tom.
                    Perhaps you missed the announcement at the top of the page, you need to start your own thread, not open a 3year old thread of someone elses.
                    http://forums.iboats.com/announcement.php?f=21
                    Don S.
                    Please, no PM's (Private Messages) regarding boat/engine problems.
                    That is what the forums are for.
                    Only forum/moderator issues will be answered in PM's.
